Hmm hold on, that's nearly a meter, for just the back pipe, where is that attached to? somewhere deep under the car I haven't a chance of reaching?900mm
Backplate to flexi-hose. It bends up much smaller.Hmm hold on, that's nearly a meter, for just the back pipe, where is that attached to? somewhere deep under the car I haven't a chance of reaching?
@mrscalex you are a star BTW, thanks for herding this newbie onward![]()
Mole grips or hammer a slightly smaller socket onWell, I did manage to remove the nasty 16mm bolts, seriously, why didn't I think of tuning the wheel?!? probably because I had made sure the wheel was 'locked' before lifting the car...
Anyway, all off, but now I'd like to remove and change the wheel arches (I have clean ones from @spurs fan in a coupe ) but I'm completely stumped by a PLASTIC bolt of all things. that one just won't bulge, no socket, pincers will turn it. Really annoying.
I also noticed the arch from the driver side is held by ONE 10mm self taping, plus that plastic bolt, nothing else! Nice work, whomever reassembled it last time :/
The good news is that the new front brackets DO work with the 300mm discs, now I'm getting paranoid about everything. How do you guy get anything done when each bolt is fighting with you?
Yes I bought one from amazon, the one with a hand pump. Tested it by itself and it seems OK, so I'll use that!Did anyone mention a pressure bleeder? Invaluable thing in my opinion, never used to think so until I got one, and now wouldn't be without it. Doesn't get used a lot, but really good when needed.
Read this and you'll understand: http://messybeast.com/dragonqueen/real-haynes.htmHow do we get anything done when every bolt is fighting back? Patience, swearing, and experience. None of these things can be taught over the interweb, unfortunately.![]()
Yep, based on years of experience that lot'll be true. Shame they couldn't have given that kind of advice while I was doing my apprenticeship.Read this and you'll understand: http://messybeast.com/dragonqueen/real-haynes.htm
I had a box of them, but I've been chewing on them as I worked to go over the frustrating bits. Helps a lot!![]()
Glad to see you managed to remove the 40watt lightbulb from the braking system..... It's always hard to get to, that one..
