Craig P Steffen
- Joined
- Jun 18, 2019
- Points
- 1
Hi folks,
Short version: what thing on a Z3 pulls 140mA and cycles on for one minute and then off for one minute, continuously? I have a friend whose Z3 is having battery drain with this characteristic.
By the way, I'm looking for someone who has experienced (and ideally fixed) this very specific problem. I don't need general overview about batteries, or voltage, or grounding, or looking for leaks. (I appreciate that, but if I get 20 people telling me how to hook up an ammeter it will be difficult to find the specific information.)
2000 Z3 Roadster (the convertible not hard top). 2.3 L engine, manual trans. Battery in the trunk.
I'm helping a friend track down an electrical leak. Several car people (and I think at least a semi-pro mechanic) have looked to no avail. I put an ammeter between the battery and the chassis and pulled fuses to isolate it to one circuit. It's circuit #31 (5A fuse), which in the fuse cover is listed powering the following items:
- antitheft system
- Clock
- Electronic Immobilizer
- Exhaust gas diagnosis
- instrument cluster
- on-board computer
I was hoping it was the clock. I pulled the radio last night, got down to the clock, and pulled the three-conductor cable off the clock. It wasn't that; leak still there.
The behavior of the leak is the following. When monitoring the drain by putting an ammeter between the battery negative and the chassis, it cycles between about 25 mA and 170 mA. Almost exactly one minute at the high current, and then one minute at the low current. (My best estimate is 57 seconds on, 57 seconds off; I don't have a real precision electrical meter so I don't know what the real sampling rate is.) Having removed the radio, the leak is now down to about 5 mA, so I think most of the 25 or 26mA quiescent drain is the radio itself.
Anyone every seen anything like this? I would think it would be very specific if you had.
Thanks for any information. Sincerely,
Craig Steffen
- antitheft system
- Clock
- on-board computer
Craig Steffen
