this is a bit of a weird one...
bernd
A little spider had decided to crawl behind the screen of the Z3's instruments, presumably via the reset button, and has then promptly died. So now there is this dead spider stuck right underneath my speedo and it's really annoying me. It's almost as bad as the check engine light being on. So if anyone knows "The quick and easy way of removing a dead spider from a Z3 instrument cluster, I'm all ears...
ExMX5owner
Moderator
Staff member
Australian Zeds
Queensland, Australia
If it crawled in there via the reset, it should come out the same way with the help of a vacuum cleaner.. I dont know how to use one of those, I would have to ask my wife...:whistle:
Ha,ha, and you might be going in to join it Shawn.=))
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
It's not dead. It's only sleeping. The norwegian blue prefers sleeping on his back. Probably pining for the fjords.
Er.
Maybe in the short term put a thin black pinstripe along the bottom of the glass so you're not looking at it when you should be looking at the road 🤷
Might end up a longer term solution because I don't know if a hoover would have enough suck to budge it. Also, if I'm not mistaken, the glass front is glued into the panel so even if you took out the panel you wouldn't get the front glass off.
I know yours has shuffled off this mortal coil. But I'm a right mug for wild life, I am, and if I ever saw a live one pacing up and down behind the glass I'd have to do some thing drastic to save it - like strip out the panel or drill a hole to push flies through to feed poor old Octavius. There I told you I was a mug. I've even named it.
RIP Octavius :(
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
Oh my gosh, I am on a work call and just snorted when I read this. Well played, sir!
To the OP's conundrum, I'd suggest removing the cluster from the car and then following this guide to split it open and remove your stowaway
Give the vacuum cleaner a go over the reset button if that fails remove the cluster and dismantle it to get to it. Z4 clusters come apart easy enough Z3 should be similar.
They are easy Col. I did a "How to remove" on a Z3 some years ago.
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
I have an empty front cluster part with no wildlife inside, if the worst comes to the worst.
Open to high offers! ;)
