My Z4 ........................... My Way (Part 2).
MisterP007
German Engineering - Italian Clothes
Tunbridge Wells
Nice beastie
ktnez99
West Midlands
Z3 2.8L
It’s white: good luck with that 😂
That roof is amazing! The door cards are pretty cool too.
gookah
Shropshire
2.8 Z3
Angel Eye LED kit should be here later tomorrow Pete. Sat looking at it over a cup of tea this afternoon thinking about the sills. There are quite a few small bits of gravel rash at the rear ends of the sills and I do still have some vinyl.
Sadly villa sticker may soon be redundant mate.:(
Is that because the sticker is not suitable, or the villa is going?:(
PS why do you have Roy's (@Rha ) car on your avatar.......
It's looking as though the villa will have to go Pete. It's been empty for nearly 18 months now and even though it's running at minimum cost that still adds up.:( It can't go on much longer and if Biden doesn't open up to tourists from the UK, well ...................
ps. I'll tell 'im to get his car off my avatar:thumbsup:
Thank you Tony, it really is a nice car. Drives like new.
Yesterday saw me apply a piece of carbon vinyl to the front bumper centre section as an experiment but I quite like the effect so it's probably staying.
It looks nice too in the back lit pictures.
To be honest a professional "wrapper" would no doubt have made a better job of it, so as I have plenty left I might do some research and revisit it later.
Tomorrow's little project came in today's post,
And as I had neglected the Shed for a bit I thought I would sweep up all the rust that fell off the old grey thing when me and Roy (@Rha) had the front end in bits.
Today's little project involved a pair of these.
Simple enough to fit. Remove the cover,
Then the old Halogen bulb.
Disconnect the plug and insert the new LED "bulb". Simple bayonet style fitting, a bit fiddly but easy enough. Connect the new wiring and place inside the headlight body.
Switch on an make sure they work.
Compare with the old halogen light in the other light unit.
Do the same at the other side and replace the covers.
Check they both work OK.
And later at dusk.
I should have had just ignition on instead of sidelights and not had the red glare at the back.
Also today got my phone paired and connected, found out how the USB works and set a few radio stations. Had a visit from Keith and Denise too.
ZEDonist UK
Cambridge, United Kingdom
3.0 Roadster
The LED halos looks a lot more modern I will give you that. But I do like the firey, devilish, Middle earth appearance of the standard bulb.
Do you know what temperature the new bulbs run at?
Martin
These are the Specs. for the LED s Martin.
Voltage:DC10-32V
Wattage:80W( per each) *
LED Type: CREE chip
Easy to install and very bright
LED Quality:8pcs Cree Chips each lamp
6000k LED white color
Super Bright LED, up to 1000 Lumen / Pcs
Aluminum body for fast heat releasing (No overheat) *
4x 5w CREE chips (USA import) - total is 20w (up to 1000lm) per bulb *
No OBC/Canbus/Computer bulb errors OR radio interference
1 Year Warranty
BMW Car Compatibility Below
OhioZ4
American Zeds
Ohio USA
E85 2.5i Sport
Great looking car without a doubt . Thats the model/color combo I told my wife is next for us .
Next project is getting an Acrylic panel made for the wind blocker between the seats like I did for the E85. This is for mounting my rear facing camera and for displaying my forum name. I cut down the old template for the E85 one.
Just need to visit Trent Plastics in Gainsborough tomorrow, up the road from another place I have to visit re another project.
