Manifold
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift
@rmoconnor41
You can do it with the manifold on, however people say it only really works when fitting genuine bmw parts
So if it was aftermarket then they most likely took it off
I have just finished changing the PCV/CCV on mine, and took the intake off, both to make the job easier and to replace many other pipes under it!
rmoconnor41
@rmoconnor41
The PCV was genuine BMW
Smudgemanuk
Bicester, Oxford
Good for you going genuine!
Then I presume we can only guess they had the intake off, as seen through the missing nut
However, I have heard it is definitely doable with the intake on.
  • Agree
Reactions: Lee
It is doable, not too difficult at all, I warm the connections up with a heat gun and they clip together no problem.
Smudgemanuk
Bicester, Oxford
The things you learn from doing it regularly!! No wonder mine took a bit of a shove to go together!
I used a bit of silicone grease on the o-rings which helped a bit,
hopefully I won't have to change it again, but your method sounds good
Reactions: Lee
rmoconnor41
It’s annoying when you learn these simple tricks after you have struggled. Ant Stark and I struggled with a top gasket falling out only to watch @Lee hold it place with a zip tie. 😡
  • Agree
Reactions: Lee
AntStark
Hampshire
2002 3.0 Sport
Personally I blame lack of common sense 😀
rmoconnor41
This could well be the cause of all your issues. you'll be loosing vacuum and sucking air in! I think they're M7 nuts using a 11mm socket, very BMW specific.
Apparently they were missing before the PCV was done but didn’t affect the smoke test
Works the other way round during normal running mate, when we smoke test we do a positive pressure test where the smoke blows out, when the engine is running its running the opposite under a vacuum. Still stands this could well be your issue.
rmoconnor41
Thanks. I assume that some parts need to be removed for access to torque them down properly
rmoconnor41
Apparently they didn’t take the manifold but did spot the two missing nuts. They said that no smoke when tested but @Lee explained it could still be leaking air. Trying to find out what needs to be stripped to better access them.
Smudgemanuk
Bicester, Oxford
Taking the air distributor, wiring harness, maybe fuel rail, then you should be able to get them on
It wont be leaking air, it will be sucking air in.
Remove that manifold cover with the two 10mm nuts and you'll have clear access. 10 minute job max.
rmoconnor41
Thanks. I’ll get @AntStark my unofficial mechanic on it right away. Swapped these out.
Reactions: Lee
rmoconnor41
Monitor and repair if necessary (advisories):
  • Oil leak, but not excessive engine (8.4.1 (a) (i))
  • Power steering pipe/hose slightly corroded (2.1.5 (g) (i))
  • Power steering pipe/hose has slight seepage lower pump hose (2.1.5 (a))
  • Front Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
  • Rear Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
  • Rear Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
  • Rear Coil spring corroded both (5.3.1 (b) (i))
AntStark
Hampshire
2002 3.0 Sport
Advisory 1 is pre-filled in when you tell them it’s an old BMW 😀. All the rest is pretty trivial tbh. The front and rear subframes is just light surface rust.
Probably worth fixing the PS hose at some point.
rmoconnor41
Corrosion on pipe..they said wire wool and paint.
Might be worth replacing the mssing nuts initially just to see if it makes any difference?
rmoconnor41
and a rear disc
