How To Guide M54B30 manifold swap on M52TUB28 How To
MisterP007
German Engineering - Italian Clothes
Tunbridge Wells
Any recommendations for someone who's familiar with this swap/tuning?
Get it re-mapped or buy an ECU with these altearions built in. I used an off-the-shelf ECU and it has been flawless:
Make sure you tick the correct boxes for the various upgrades.
P.S. Keep the old ECU until you are sure all works well then send to them for a refund (£25 from memory).
Daz7401
Bristol
Z3 2.8 Auto
This is who I used for mine. If you have cruise control it might work differently (mine does). I now need to move the stalk up or down to activate it before I can set the speed, moving the stalk up or down again de-activates it. Also I put a bulb in the instrument cluster and have a working cruse control light. I think the base settings are from a 3 Series E36 but that is only opinion, I don’t know for sure. I do like the way it works now and having the working light is unusual in a Z3.
MisterP007
Tunbridge Wells
amiguels
Thank you for the excellent guide.
However I'd like to ask some clarification regarding the need for ECU tuning. Is it absolutely necessary in the sense that the car will simply not run well, or is it a matter of a tune being needed to get the most out of the intake manifold (and nothing else) modification?
Thanks.
Devon Z
Brixham, Devon
99 2.0 Individual
Just an aside if anyone reading this has a 2.0 do this mod it will transform your car.
I did mine with a manifold from a 525 sport just looked for one with the full size ports as shown in the photo.
MisterP007
Tunbridge Wells
Thanks.
No idea if it is absolutely necessary to tune the ECU as I did mine all at one time. That said, I would suggest that additional performance and fuel efficiency will result, not to mention your car will not run like a bag of spanners!
The ECU tunes for the free-flow exhaust, MB30 manifold ( fuelling needs) and a few other points.
Do it all, the difference is huge.
amiguels
I understand, and that's the final goal. But currently I'll only swapping the intake, and some months from now, maybe a year, I'll be installing a less restrictive exhaust. I'd like to avoid getting two tunes, if the car can run ok until I have the exhaust installed.
It will run fine, the ECU will make use of the extra air and adjust itself no issues.
MisterP007
Tunbridge Wells
Lee is "The Man" for all things tuning.
  • Thank You!
Reactions: Lee
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Changing the ECU:
So easy it beggars belief.
  • Disconnect the battery and leave things alone for a while to discharge current in the system
  • Unscrew the 5-screws that hold the cover in place for the ECU/Relay box. Liftoff.
  • The ECU is mounted vertically and comes out easily once the connectors are pulled
  • The two end connectors have side latches that can be pushed in with a screwdriver, the middle connectors have a top-mounted tab and a release lever.
  • Once all disconnected pull the ECU up and out
  • Slide the new one in and re-connect
  • Screw down the lid
  • Re-connect the battery
  • Turn the ignition key to position 2 for 90 seconds and do not touch the accelerator cable (the ECU learns the throttle position during this)
Job done!
View attachment 199535View attachment 199537View attachment 199539View attachment 199541View attachment 199543View attachment 199545View attachment 199547View attachment 199549View attachment 199551View attachment 199553View attachment 199555View attachment 199557View attachment 199559View attachment 199561View attachment 199563View attachment 199565
Job done so lets see how it works out ...
Wookiki
Hello!
This was an amazing write-up. I have been doing a lot of research, as this will be my first intake manifold swap from m54b30 to a m52b25tu. I'd love to ask if you don't mind, do you have any insight as to whether if the IM swap process is the same as the one written above or would that displacement difference create complications in fitment? Mine is the 2.5L m52tu. any insight or recommendations would be so greatly appreciated.
Best regards
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Best ask @Lee ….
Hello!
Best regards
Works well with the 2.5 also, wont be documented here as we didn't get the 2.5 Z3, that was an American variant.
Wookiki
Ah, I see. Great to know that it will work the same. I just ordered the parts and am going to swap them here soon when the parts come in. Once the swap is done, I can come back and confirm how the process went.
Wookiki
The project was a success, m54b30 intake manifold directly fits on a m52b25tu. The performance difference is hard to tell without a tune. We will see what a tune does.
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
Did you change the ECU too? (And if so, did you get it from the website in the guide, and how long did it take to arrive?)
I am currently gathering parts to do the same thing later this year.
MisterP007
Tunbridge Wells
To let everyone know:
The manifold swap (M52TUB28 to M54TU30), Exhaust and ECU upgrades are all still running very nicely with zero issues, goes like a rocket and about 30-32 mpg average.
