Hi All
Just wondered if anyone has any experience of using the STP gas and gauge on a Z3 3l engine. My air con was not getting cold, checked compressor was engaging etc and all seemed ok so decided to try recharging myself.
Followed instructions and the gauge showed low, did the recharge with the engine running and compressor engaged, filled until the gauge was in green. All seemed great lots of cold air coming out of vents.
My worry is that although gauge needle shows green when the air con is working it goes up to the red Warning when the air con is turned of, any body know if this is correct or had similar experience.
Thank you and any help appreciated
