Hello,
I have a 98 Z3 2.8 in Arctic Silver. I’ve never used a Forum before so a little unsure on the site navigation side. I have a very strange anomaly with my electric roof that I’m hoping to resolve.
Quite confused and on the verge of losing my mind with my roof wiring. Maybe I need a fresh set of eyes to see what I’m missing. Brown and red wire between relay and switch had been cut by someone, close to the roof switch in centre console and an ignition live from radio wired into the switch there (marked with red dot). I cannot understand how this allows it to operate but it somehow does, with no need to have foot on brake to operate roof, in fact pressing brake pedal stops it from working. I disconnected the ignition live and ran a wire directly between relay to switch to bypass existing brown/red under the carpet which, as it should, has a live feed only with brake pressed but roof will not open with this correct wiring. In terms of the connector block at the motor/pump, I’ve got 12v at both red/yellow wires to relays. I have 12v blue/red from brake light switch when pressed and 12v from the wires from the relays brown/yellow, brown/red. Any suggestions would be gratefully received!
