Has anyone had their 2.8 remapped? I know the gains aren't significant on a normally aspirated engine but ones I've had done in the past have felt a lot more responsive.
Many thanks
my car is a March 99 build and has the TU engine which I believe is double vanos? Please correct me if I am wrongA remap would be more with it in conjuction with some different bits.
If your 2.8i is a single vanos engine (pre Sept 99) you can fit the "M50" 325i intake manifold.
This is a favourite mod to this engine which allows better airflow. Perhaps with some uprated injectors, higher flow exhaust and air intake might net you 15bhp more with a remap.
Both those engines get great gains. As said above the single vanos uses the E36 325i inlet manifold and the TU engine uses the M54B30 inlet manifold + injectors. My 2.8TU made a healthy 235bhp with 315NM of torque quite a bit more than the 3.0, she did have a fair few more tweaks than just the manifold.my car is a March 99 build and has the TU engine which I believe is double vanos? Please correct me if I am wrong![]()
M54B30 Inlet Manifold - Ebay ListingThanks for the replies guy's, mine's a 2000 year so I assume a TU engine, certainly sounds like it's worth a go then![]()
Well there's no doubt his car is coming back to the right place for a refresh! Can't wait to see Dave's 2.2i when you guys have finished with it.![]()
Yeah looks good that, the biggest issue you have is the throttle body the 2.8TU it's very restrictive along with the intake. I converted mine to the 3.0 throttle body due to it being far larger so you would need the engine loom they are plug n play and the only connector different is the throttle body connector. The airbox and maf is also alot larger. I didnt have the 3.0 cam but did have a nice set of exhaust manifolds, the cam would of been the last thing to change in my quest for power at the time.M54B30 Inlet Manifold - Ebay Listing
Injectors for M54B30 - Ebay
Inlet Camshaft - Only need the inlet and not the out IIRC
@Lee - Can you confirm if the above links are the correct items for squeezing a few extra ponies out?
So what is involved in putting an m54 3.0 throttle body on a 2.8 TU?The M54 is fly by wire, the M52 has a throttle cable but the ASC motor on the throttle body can snap the throttle disc shut. The throttle body was the same on the 2.0, 2.5 and 2.8 so it's a bit on the small side tbh.
SA Tuning says with a decat and a cold feed and a stage 2 remap it will get 247bhp and 325nmCan anything be done with a 3.0 engine? Just out of curiosity
Thanks Eddie, I assume you've had the 2.8 remapped too and there's a noticeable difference with that one as well.I had my 3.0 remapped a few months ago. Not for the huge HP difference, about 10! But more for the driveability. The results are pretty good with an increase mainly in low and mid range performance. I'm lucky to also have a 2.8 twin vanos Z3 as well, the difference is very noticeable in the acceleration and power delivery. The other mods will get you more power, but for the money and convenience, I think the remap is worth it in itself.
