What to do when the washer bottle has sludge inside?
Cathia777
Eastleigh
z4
Any idea how I can sort this problem by using a (cleaning?) product? I wouldn't dare to remove the washer bottle myself :(
Thanks!
PhilH67
Derbyshire
Easy to remove the bottle, disconnect the pump connector and the 2 (if I remember rightly) 10mm bolts and it pulls out. Then get some Milton in there and leave it soaking for a while, empty, rinse and put it back in the car.
Cathia777
Eastleigh
z4
Thank you!
IanA
Oxon
Or put it in the dishwasher while herself is out...
AntStark
Hampshire
2002 3.0 Sport
E85 removal is different .. but Milton fluid is a good shout.. give it a scrub with a brush if you can and remove the scummy fluid after .. refill
PhilH67
Derbyshire
Ahhh I didn’t spot that sorry, yeah ignore what I said about removal, I was assuming Z3.
anyone care to elaborate on washer bottle removal for a Z4?
Put a garden hose into the bottle on a slow fill. Allow to over flow. You need to remove the pump because the filter WILL be clogged with the slimy crap in the bottom. To remove the pump simply lever it out of the bottle using a large screwdriver or similar. Reomove the seal/filter the same way. Wash or blow out the filter and replace. Replace the pump and add some of the Milton solution and operate the washers to flush the system (including headlight washers , if fitted). Pop the pump out again and drain the bottle, flush with hosepipe. Replace pump and refill.
