Upgrade headlights
My MGB's lights are Cibie 7" units with plain H4 bulbs.
Not standard 48 year old MG lights then.;). Cibie made great lights back in the day, are they still making them now?
My late brother had a pair of Super Oscars which went on every car he owned.
Just as a "by the way" if your car has electric motor up/down adjustment you can make big adjustment by removing the motor from the rear of the lamp unit and physically screwing the motor's rod in or out depending on which you need, thus leaving the limited motor travel for fine adjustment.
Another thing to check is that the reflectors are still attached to the adjusting screws and that they haven't been over adjusted and popped off the ball joints on the ends of the adjusting screws. You may need to remove the light units to make sure. If you pull the rubber boots off the back of the bulb fitting you may be able to tell if the reflector is secure or not.
