New parts decent price I think
Disky
Apprentice Zedder
Falkirk
Ok so got a price from BMW for original parts today
2x Z3 sills for my '98 1.9
2x rear brake plates (bits that handbrake cables attach to)
All in £310.53
Thought that was decent for genuine BMW parts
Low Rider
All in £310.53
I'd go with that. Think I paid £50 ish for my back plates it's just fitting the dam things which is the problem.
Chappo
Leicestershire
Z3 2ltr. M52TU
I paid £205 for a set of new sills. Now just need to paint them...:( that's the costly bit
I paid £278-00 10% discount inc vat for a pair of genuine bmw sills
& £60-00 for a pattern o/s front wing (but very good quality) then I sourced a
Painter who charged £200-00 including paint,stone chip & sundries. (One quote for painting was £295 + vat robbing gits. Anyway the painter made a superb job & the colour match is spot on.
Before you start fitting them I suggest you buy some clips for the top sill moulding (the one with ROADSTER ON IT) as you will no doubt break a few regards CHAPPO.
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Where was the pattern part from? Bmw want £184 each!!
Chappo
Leicestershire
Z3 2ltr. M52TU
Pattern part from. Imperial Automotive Ltd. Phone 0845 050 9299
Cross Bank, Fax 01302 322573
Carr Hill,
Balby
Doncaster
South Yorkshire
DN4 8BE
SRP £116- Price £50-36 + 20% vat
Total £60-43
Part number BM307BEACR
BMW Z3 97-03 o/s front wing
Hope this is of some use rearguards Chappo
roadvoyager1
Shotley Bridge
2.8ltr
I also bought a pattern front wing from e e-bay. It was a different seller, but they were selling Imperial Automotive parts.
I found the panel edges had severe burr edges (ragged cut edges) and I filed these off prior to getting them painted. Burr edges will result in rust starting so careful preparation is essential.
I also had a re-cycled front wing (other side) which I removed the surface rust from and treated. I feel that this was better than the pattern part when finished. Time will tell.
Sills from BMW were well finished and needed no remedial work before spraying.
Chappo
Leicestershire
Z3 2ltr. M52TU
The pattern o/s front wing i purchased had no ragged edges or faults of any kind & was galvanised.
At £60-00 & a massive £123-00 cheaper than a genuine part it’s a NO BRAINER.
I personally would fit the pattern wing (of the quality I purchased) sooner than fettle a rusty genuine unit.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
All in £310.53
Which dealer? I need a pair of sills.
jaguartvr
I cheated when fitting the rear brake plates. Cut a slit in the narrow section that allowed me to slip the plate on without having to remove the hub.
A blob of weld to make good but you could probably get away with using JB weld as it is securely bolted on.
You will have to adjust it by levering with a screwdriver to make sure it is not rubbing on the disc.
