When refitting my handbrake cables I managed to drop the small double holed link plate that fits across the end of the ends of the two cables before the adjusting and lock nuts are fitted. It seems to have gone down the side of the trans tunnel under the carpet. to get it out would seem to be a seats and carpet out job and one that I would prefer to avoid at present.
I have checked on RealOEM and this part is not listed. My local BMW dealer says that it comes as part of the handbrake lever assembly.
Can any of our resident parts suppliers (@spurs fan in a coupe, @mrscalex , @Synclare ) help with a replacement link plate?
The purpose of this plate seems to be to spread the force of the square tube under the hand brake lever evenly to the adjuster nuts. It doesn't, as I originally thought act as a balancing system. As such could the plate be replaced by a couple of thick (1mm) washers?
