Rebody Fibreglassing help
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
I am going to have to do a bit of fibreglassing as I can't avoid it!
My questions are:
For very small areas, ie 5mm x 600mm x 10mm thick can I use pre-mixed fibreglass filler? Will it be strong enough?
I want to make very small makeshift 'moulds'. Do I need a specific release agent for the mould or will any wax do? I have carnauba and some beeswax-based stuff for furniture. Any good?
Will I need gelcoat, or will just matting and resin release from a mould OK?
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
5mm x 600mm ?
That's like a narrow slot 2 feet long. Joining two panels? Or are you adding to the edge of a panel.
For 5mm I'd use the filler with fibre in it like isopon P40.
But I don't just stick it on. I really chop into the edge of the panel to rough it up. A lot.
I don't use gelcoat. I get the grp filler just below where I want the surface to be and skim with smooth filler. Something like P38. Then filler primer.
Pond
Spaldingski, Lincs
Thanks Ian. :thumbsup:
I am hoping my paintshop will do these bits for me, just ascertaining what is required if they can't (or won't).
